I am still a little new to this world and I want to build a plane using a coaxial motor set up. Where I am having a problem is learning battery needs for the motor. I will put the specs for the motor down below.
Is there anyone who can help me understand what I need for a battery. I am hoping for a couple hours of fly time or at least as much as I can get.
Any help where someone can help me learn to extract the information needed would be greatly appreciated.
Weight: 275g, (9.7oz) with prop adapter
Max Power: 800W, (This is dependent on several factors)
Max RPM: 12,000 RPM
Diameter: 35.3mm, (1.39")
Length: 64.3mm (2.53")
Shaft Diameter: 4.73mm (3/16") front shaft, 9.48mm (3/8") rear shaft
Motor Mounting Holes: 4 holes, 3.17mm through, on 43mm, (1.7") bolt circle
Maximum Case Temperature: 65oC, (149oF)
KV= 1030, Rm = .0.035, Io of front motor = 4.8A/10V, lo of rear motor = 2.3A/10V
Efficient Operating Current =30-36 A per rotor, 40A Max 15 seconds per rotor.
Suggested Props: For 3-cell operation APC 12x6P front prop, APC 11x8E rear prop
Battery: 3-cell Lipo that can sustain 70 to 80 amp continuous draw.
ESC: Two 35 Amp ESCs or equivalent. Also needs a MPI 2160 or 2460 Y-harness to join the two ESC to throttle channel.
Max RPM: 12,000 RPM
