S stereodreieck86 Active member Nov 27, 2019 #1 Nov 27, 2019 #1 Hey guys, can you help to identify the motor shown below ?
J Jaxx Posted a thousand or more times Nov 27, 2019 #2 Nov 27, 2019 #2 Do you remember where you purchased it?
S stereodreieck86 Active member Nov 28, 2019 #3 Nov 28, 2019 #3 Jaxx said: Do you remember where you purchased it? Click to expand... I think from Hobby king, I looked it up but could not find the motor. Update: Its either a 2210 or 2208. https://www.diytrade.com/china/pd/1...900Kv_for_multi_rotor_aircraf.html#normal_img I have measured 8 mm stator height, when I measure the stator height including the wire it is 10 mm. Interestingly enough, the motor also appears to be available in a 2150kv version Last edited: Nov 28, 2019
J Jaxx Posted a thousand or more times Nov 28, 2019 #4 Nov 28, 2019 #4 This one maybe? https://hobbyking.com/en_us/2210n-1000kv-brushless-motor.html
S stereodreieck86 Active member Nov 28, 2019 #5 Nov 28, 2019 #5 Found it: https://hobbyking.com/en_us/floater-jet-replacement-motor-axn-2208-2150.html
