Hyderabad RC list
4 Servos
Like these
One
Y lead
Pack of
Servo extensions
ESC-
30A emax or a
Skywalker which they may do in 30A. Will double check the motor spec.
Cheap 1100kv motor, I have flown my simple Scout on these, flies fine and will be heavier than the Storch as it’s UK board, which weighs more.
Two
10x6 SLOWFLY type props, these are out of stock but easy to find, make sure they have adaptors included to fit motor shafts.
Larger battery. A bit heavy but Indian stock.
Charger, same as the Hobbyking one.
They don’t seem to have linkage stoppers, which you use on the aileron servos to adjust the length so they sit dead level when centred, they can be got easily elsewhere. You want 1.3mm holes and smallest possible (M2) threads.
They do sell
Flite Test kits, including the Tiny Trainer which I think is better than the Storch for learning. That would want a smaller 2300kv motor, 20A esc and two 3.7g servos on the wing, otherwise the same.
You will need bullet connectors and battery connector of your choice too.
Hobbyking list
Servos
30A esc
Y lead
Servo extensions
Motor
Props
Battery, note any 3s 1800-2200 30c will work.
Charger
XT60 connectors , for the ESCs.
Linkage stoppers, out of stock but that’s the size for FT pushrods. You can do without them if you are good at modified Z bends.
