So I've been using my new jumper t12 with a new inductrix fpv plus. While I have gotten it to work it's not setup the way I want it to be.
The main issue is when I programmed my switches for the motor arming and the flight mode selection. I did get my flight mode switch to work correctly but the LEDs on the back indicating the flight mode are reversed. Red should be agility mode but its altitude hold mode. Blue which is the middle of the 3 position switch is correct for stabalized flight mode. And then when the light is green it's in agility or acro mode instead of altitude hold mode. This isnt that big if a deal but does seem odd.
The big issue is I can only get the motor arm switch to work with my s2 rotary nob. When I put it on one of the 2 position switches it doesn't work. Any ideas with that?
Thirdly. How far should my range me on this little quad? I see YouTube videos of people flying then really far away with fpv. I'm flying line of site and I'm loosing signal at what seems under 3 to 4 hundred feet.
I attached some shots of a few settings. The only thing o change on the switch is changing it to s2 and it works
Any help would be appreciated, thanks
