Hi all,
First time building a quad, here's some specs:
alien 5" frame
mr steele PDB
KISS FC v2
KISS ESC 24A RE
Emax RS2205 2300KV
Since I first connected the FC to the PC I've been getting a wierd behaviour on the quad's model, at the 'data output' tab (See links below). Figured it would be because it wasn't setup.
Finnised the build and can't get it to lift, the motors go nuts.
Took it all down to start soldering from scratch, but just wanted to make sure the behavior of the gyro/acc from the video make sense.
More info:
- all 4 blue leds and the green one are lit.
- tried several PID's,
- flashed the fw on both fc and ESCs.
- while testing individualy, the motors go in the correct direction.
- Calibrated the throtle and i get around 1500 (+-1) from the receiver.
Could you shed some light on what might be happening or point me on the right direction? Is this model behavior normal? Is the gyro bad?
Thanks in advance.
alien 5" frame
mr steele PDB
KISS FC v2
KISS ESC 24A RE
Emax RS2205 2300KV
More info:
Thanks in advance.
