Mustang7302
Trying to sort through flight issues with my new Bat Bone build. The biggest issue I am trying to sort through is getting the pivot to re-center itself after direction left or right is given; it gets close but is still off enough to make the tricopter spin like a top when it takes flight. When testing the setup at low throttle, I have found on a few occasions as I give left or right yaw that suddenly the power to the motors ramp up quickly and I have to chop the throttle off. Even just trying to watch the rear motor for stability with the throttle at like 25%, several seconds later the power to the motors ramp up again to just about taking lift and I have to chop the throttle quickly.
A quick Google search didn't find much of anything on the topic as I describe it. Has anyone else experienced this?
Even when I reset to factory defaults, set the tricopter layout, set the auto level to aux, the power will slowly ramp up and then burst into power to provide lift and I am forces to chop the throttle quickly.
I am willing to take any ideas I can get at this point.
- KK2 with v1.6 firmware (may have done it on v1.2 as well, but I was sorting through other issues to really take notice.)
- Tricopter motor layout
- PI Editor:
Roll & Pitch:
P Gain: 100
P Limit: 100
I Gain: 70
I Limit: 70
Yaw:
P Gain: 70
P Limit: 40
I Gain: 40
I Limit: 20 - Stick Scaling:
Roll: 30
Pitch: 30
Yaw: 50
Throttle: 90 - Misc. Settings:
Min Thrott: 10
Height Dampening: 0
Height D. Limit: 30
Servo Filter: 50 - Self Level Settings:
P Gain: 35
P Limit: 20
ACC Trim Roll: 0
ACC Trim Pitch: 0 - Mix Editor:
Ch1: Stock
Ch2: Stock
Ch3: Stock
Ch4: Rudder @ -100, Offset @ 55 (sets pivot level), Rate @ High - ESC's were calibrated a couple of times.
- RCTimer 750KV Motors
- RCTimer 20A SimonK ESCs
- 10x4.5" Props
- 4000mAh 4S Battery
