Try-n-glide
Planning to run a test of 1.7 mil laminating film on a balsa build. The basics if you haven't heard of this product, is that it is much like traditional covering film except it is clear and doesn't shrink much. Aloft Hobbies sells 18" rolls at $.65 ft - so it is pretty cheap.
So far I have laminated a foamy wing leading edge for strength, and it worked reasonably well. It certainly doesn't stick to itself like solite does. The downside for balsa is it is heavier, and also needs paint unless you want a clear plane.
So I made a small frame and covered it. Then scuffed it with a green scotchbrite pad. Shot it with primer. Shot it with white. Taped it with low tack painter masking tape. Shot it with red.
Results to follow after the paint dries. If anyone has experience with this stuff I'd appreciate your comments.
Seems like the ability to buy it cheap and spray it with hardware store paint might allow some flexibility over $15+ rolls of solite but it remains to be seen if it will hold up.
