synjin
Okay, this is the last one in the J-Series! After this it's back to tandems.
Anyway, I was going to put the J's aside, but I had the whole Lazy Bee out of foamboard thing in my head. So, I pulled out the Lazy-J plans, widened the wings, moved the dihedral lines out to make them polyhedrals, changed the wing-saddle on the fuselage, and modified the nose profile. I had to increase the size of the tail surfaces to keep it similar to the Lazy Bee's. I'd have put 2" foam wheels on it but didn't have any, so I repurposed wheels off of a dead Mini Scout.
Threw it up in the air for a maiden today. Got the CG right and it only took a little trimming to fly straight and level. It's slow. Slower than the Lazy-J, and it's much slower than the J-3 Cubbish. I feel confident that I can fly this in an elementary school gym it can be so slow. On the other hand it can go when it's throttled up. It loops, rudder rolls, kind of wing-overs...as much as any three channel can. I was surprised.
On the other hand, I think that this is as far as I can go in this series and still use an A Pack for power. A 2205 motor might be better. I'd intended to put a 2205 1400Kv motor on it with a 7" prop, but I wanted to see if the 1806 would fly it. There's a half ounce of weight in the nose, and I also had to use a 3S 900maH battery to balance it. The other two J's balance with 2S 900maH batteries.
Lazier-J
by Andrew Long/synjin
Motor: 1806 2400Kv
ESC: 12a
Wingspan: 30.25 Inches
Length: 20.5 Inches
Weight (without battery): 200g-ish
2 5g Servoes (but you could use 9g servoes as well)
Version 1
The J-Series.
Here are Version 1 plans should anyone want to build one.
Edit: Redesigned the fuselage to reduce twist while building.
Cheers!
Lazier-J
Motor: 1806 2400Kv
ESC: 12a
Length: 20.5 Inches
Version 1
The J-Series.
Cheers!
