Hai-Lee
Old and Bold RC PILOT
I have been searching for an appealing build of late and so I have been hitting the internet looking at the various plans and designs. During my search I came across an OLD SCHOOL solution to the prop breakage issue.
If you brake the ESC it is possible to have the prop stop pointing vertically and then of course you land on the tip of the prop first. This almost guarantees a broken prop. Whereas a free wheeling prop can also hit the ground in the vertical position and also break.
The old school method used on an early electric offering was to have a servo that put an obstacle into the propeller disc thereby causing the prop to stop rotating. The obstacle was positioned such that it stopped the prop horizontally every time. A windmilling prop would not only stop but be held against the stop by the aerodynamic forces acting on the prop itself.
This is something that intrigues me. Whilst I do use a lot of folding props on my glider designs they tend to be expensive and in the hands of a newbie they often break when the newbie opens the throttle too late for a go around. A cheap servo can cost far less than a good prop!
It could be something that I use on my motor glider designs as an option from now on!
Have fun!
Have fun!
