Wing Connection Details...
Fuse cutouts added on the upper sides.
Bottom Right View. Plywood plates to distribute connection loading.
Deconstruction of wing connection, remove fuse parts. Shows 1/4" bolt.
Deconstruction of wing connection, removed 1/8" plywood connection plate. Shows 3/16 foam board spacers between wing and plate.
All upper connections componentes removed. Wing 1/4" bolts only
Inner wing details, foam spars, 1/8" plywood soars. Foam board ribs to transfer the connection load to the fuselage wing plate.
Removed ribs showing bottom wing foam board sheet.
Next wing and nacelle construction...
