Melting Foam? Not Any More!
Baron VonHelton
As I stated, I use air guns to paint my aircraft with, not aerosol sprays or paints with fluorocarbons. As a result, I don't have melting foam. Also, just a small pump is all I seem to need. It gets the job done!
:cool::D(y)
Burnhard
This looks promising. I had some bad experiences with the flite test foam board and my usual spray paint in recent months. Originally I used some foam board from Amazon and that worked great for painting with spray paint. Had good adhesion with the paint. On the recent SBKs I had the problem that the paint peeled of from the paper on the first build. The second build got a good scuffing but that resulted in the paper soaking in the paint which then seemed to melt the foam under the paper (never had that on the other foam board). I am considering to move to an airbrush system but am not yet sure what to get.
Baron VonHelton
See, that's why I posted this. My paint doesn't peel. I don't need to sand ANYTHING. And, it doesn't melt foam.
SSgt Duramax
I've experimented with the thinned acrylic from a HVLP sprayer and a compressor (what is the sense in cluttering my area with more equipment when I have it already).
I've never had problems with the spray paint cans as long as I am careful, and if you minwax/wood glue before hand you can't really mess it up anyways. I must share the sentiment that I dislike painting the brown FT stuff. I am sure it is good for what it is, but I have no need for it, and it overly complicates things, and it doesn't really do anything more than what dollar a sheet DTFB and minwax already does. But the worst I do with moisture is fly in light rain.
I've pretty much gotten to where I slap on acrylic with a brush and just roll with it and it looks good enough from 10 feet. Although I may just start going the "rasterize" route since I am printing the plans anyways.
Baron VonHelton
The only down side is that occasionally it will clog, and I just unscrew the silver front & blow into it like a dart gun & reattach. Good as new.
Baron VonHelton
My Pfalz E.I is my first plane. It's easily months old. As you can see, there is no peeling of paint.
Yup that stuff will stick to glass and polished stainless. Good stuff for water solvent paint
