Me 109e Specs
Wing Span: 975 mm
Length : 823 mm
Motor : NTM Prop Drive Series 28-26A 1200kv / 286w (short shaft version)
The Fuse is exactly 30" long to fit Elmer's foam board 20" x 30".
The power pod will be a different design to lower the motor closer to the 109e engine center line.
Will also widen the landing gear a bit for ground stability.
Horizontal tail fin is lower then scale because the logistics of scale design doesn't lend itself to foam board. You can add the horizontal tail fin support struts for a more scale look after.
