Robert S
Anyone have any tips (or pictures) on how to stuff all of the Power, Control, and FPV stuff in the the Mini Arrow?
I put the ESC back in the power pod just in-front of the Motor but, those wires are pretty long and they make it a tight fit one they are all carefully bent to fit. I'm thinking of cutting and reordering them shorter so that they take up less space. I was afraid they would pull apart and short as I stuffed them back up in the power pod so I put some shrink tubbing over them to hold them together and to give me some peace of mind.
I'm thinking that I'll put the FPV transmitter in one of the wing bays and the Aura 5 Lite board and a Spektrum RX in the other wing bay. The only problem I see is that the Aura has to be mounted in a permanent sort of way so that it always knows which way its pointing relative to forward and level flight. I also need to be able to access the buttons and the USB port without having to un-mount it and/or move it around. When I plug in the servos and throttle, it makes the whole thing so thick that I can no longer mount it in a way that seems to satisfy all of my other mounting requirements and shut the door so that its flush with the wing.
I can't be the first to do this and, I'm not too proud to ask for help... or to shamelessly re-appropriate a workable solution.
