Foamforce
Foamforce submitted a new resource:
Mini Guinea Front Wheel Support - Replaces the two paint sticks that hold the front wheel for improved durability.
Read more about this resource...
The front wheel on the Mini Guinea is held in place by two pieces of stirring stick. A moderately rough landing will tear those out. This part goes into the cavity where the paint sticks normally go. It increases the surface area for gluing by about 10x so that it won't tear out so easily. Also, it's easier to install the collars because you only need one, and the hole for it is sized so that you can drop it in and it's positioned correctly so that the wheel wire will slide right through.
I...
