SPONZ - any chance you drew up Plans for the mini Guinea?
B balsa basher Active member Sep 9, 2018 #1 SPONZ - any chance you drew up Plans for the mini Guinea?
BridgeInspector Flite Test Groupie Sep 13, 2018 #2 There are plans but they not as pretty as SPONZ's current method. If you have built a few FT planes, they should be easy enough to build from. Tiled Full
B balsa basher Active member Sep 13, 2018 #3 BridgeInspector said: There are plans but they not as pretty as SPONZ's current method. If you have built a few FT planes, they should be easy enough to build from. Tiled Full Click to expand... Thank-you!
