Jade_Monkey07
Time for a build page! Copied the initial text from the scratch building thread
-Started my Mini Me 163 Komet build the other day. This is one I've wanted to build for a while. I saw some other komet builds on here but I am a fan of scale looks so that pudgy round shape feels essential to me. At around 500mm i Started with the wing and profile view, to be fully 3d skinned in 1mm depron after.
Wing consists of 2 layers of dollar store foam. Bottom layer keeps the paper and gets a half of a giant bbq skewer in the center as a strut and the leading edge gets the other half which is used to start the aerofoil profile. The top sheet then gets paper removed and sanded to a very sleek profile. She is going to be built for speed in mind.
So far she sits at 60 grams with the motors(yes 2) 1202.5 11500kv 2s
for now it glides very well and the wing is so strong it could take off someone's head. I am aiming for 110 grams fully loaded 2x 450 mah 2s batteries, one for each esc and a 100mah for reciever(I like redundancy in case the motors quit) and also should be able to fly with just one motor no problem if I want a more tame flight experience. The maiden will likely happen with just the pusher. it should have around 250 grams of thrust in this tractor and pusher config
Ive got the fs2a reciever ready and the Escs just showed up in the mail so I can get all the wiring done soon. I'll be short on 1.7g servos for the build so hopefully I total one of my other builds as a ritual sacrifice to Ze Komet gotts.
