MM P-82 "Banshee"
dutchmonkey
I thought i would pull this out of the Mustang build and have a place to keep the build together https://forum.flitetest.com/index.php?threads/the-big-bang-of-mustangs.61204/ . i am building a Mighty Mini P-82 i am calling her Banshee (ghost riders horse). i plan to have a few canopy configurations stock, reno racer bubble, razor back and a racer back. current plan is a pair of 2205 3s and should be quite fast with this setup ;). i have been learning how to use inkscape so my hopes are to have some real plans to share for the first time.
mach1 rc
This is going to look amazing in the air.
dutchmonkey
so the weather was not good enough for a maiden over the weekend:( and the only batteries i have that will handle the amps are a pair of 3s 1000's so she feel quite portly so even more reason for good weather. i think for rev2 i need to add a stronger spar to handle the weight i am easily in the 600 to 700g range with those batteries static pull of 18 amps each about 432 watts of power :p she will be fast if the wing holds up.
