So...after flying this guy in combat at Flite Fest back in July it's been mostly gathering dust. And for no good reason. Mainly just because I haven't been motivated to fly it lately.
But there's been a development. Tau recently gained some new developers who were really motivated and making a lot of updates. But they weren't getting the support they expected from the BOD of the group that oversees Tau resulting in frustration and slower progress than they wanted. Toss in some differences in opinion on the way things should go..and..they forked. But then the BOD talked them into coming back and working to change Tau...that went on for a few months but the frustration continued to build and about a week ago they reached a breaking point and re-forked. It was amicable and many of the devs that have split to the new project are still contributing to Tau at some level. But they have some rather interesting ideas on where they want to go and I'm very interested to see what they do. Interested enough I've been helping out as best as I can and offered the hot pink flyingF4 up for testing as well as been helping with getting social media accounts setup for the new group (more on that when they have the first public release ready.)
The forked codebase isn't ready for flight yet, it's got some fairly major fairly scary changes in it that still need testing. But I haven't been flying the knuckle Tau so I figured I'd try building the new code and see if I could get it to crash...er..uh...flash. Yeah, that's it
Figured first I should upgrade BlHeli on the ESC's since there were issues with the oneshot implementation on the older version I was running. Tried to use my new current limiter...only to have the light come on each time I tried to power up the ESC's...what the? Oh wait...yeah...got those LED's on this build...and no easy way to disconnect them. Whoops. Ok, we'll skip the limiter and live dangerously again. Was going to try using an arduino in multi mode to re-flash all 4 at once...but the limiter thing scared me and I got out my
1-wire interface and upgraded them all to 14.2 one at a time. In the process I confirmed
my suspicion from back in May that I had disabled damped light and forgot to re-enable it. Explains that! Dang, could have had it flying even better at Flite Fest
With some help from
Fujin I was able to get my modifications to the flyingF4 code applied to the new codebase and it built successfully!
Hooked it up...flashed it...and all looked good
But when I hooked up a battery to power the ESC's the
old USB gremlins I was experiencing came back
Hooking up the battery would crash GCS. And hooking it up with the battery already connected USB wouldn't enumerate.
This has been a major on-going frustration for me with this setup. And the hack of using two USB cables - one to power it through the ST-Link and one for data through the main port always bothered me. But as goofy as the two cable solution I was using seems in the quick start section of the manual STM even suggests the two cable approach:
2. Connect the STM32F4DISCOVERY board to a PC with a USB cable ‘type A to mini-B’
through USB connector CN1 to power the board. Red LED LD2 (PWR) then lights up.
3. Four LEDs between B1 and B2 buttons are blinking.
4. Press user button B1 to enable the ST MEMS sensor, move the board and observe the
four LEDs blinking according to the motion direction and speed. (If you connect a
second USB cable ‘type A to micro-B’ between PC and CN5 connector then the board
is recognized as standard mouse and its motion will also control the PC cursor).
I vented about it on the IRC channel for the new project and a few of the guys there got interested and determined to figure out what was going on. After a slight diversion due to one of them looking at schematics for the F3 discovery instead by mistake the issues became clear...and the news was not good.
My flyingF4 is no longer going to be a flyingF4
What was found is that the second port on the DiscoveryF4 board, the one used for data, can't actually power the board. The VCC line on it is being fed 5v from the discovery board because STM assumed you'd want to use that port as a USB-OTG and the F4 acting as a USB host. Which explains why the ports on my notebooks would shut down when I'd connect this board up while it was already powered. They were just trying to protect themselves.
And the way it's wired there's no good way to disable that. Bleah.
Even worse...it turns out that the way I was powering the board was sending 5v to the 3.3v net!
:black_eyed:
You see....I saw this on STM's website about the DiscoveryF4 board:
Board power supply: through USB bus or from an external 5 V supply voltage
External application power supply: 3 V and 5 V
And the same in the
manual:
• Board power supply: through USB bus or from an external 5V supply voltage
• External application power supply: 3V and 5V
The power instructions in the manual just say:
4.3 Power supply and power selection
The power supply is provided either by the host PC through the USB cable, or by an
external 5V power supply.
The D1 and D2 diodes protect the 5V and 3V pins from external power supplies:
• 5V and 3V can be used as output power supplies when another application board is
connected to pins P1 and P2.
In this case, the 5V and 3V pins deliver a 5V or 3V power supply and power
consumption must be lower than 100 mA.
• 5V can also be used as input power supplies e.g. when the USB connector is not
connected to the PC.
In this case, the STM32F4DISCOVERY board must be powered by a power supply unit
or by auxiliary equipment complying with standard EN-60950-1: 2006+A11/2009, and
must be Safety Extra Low Voltage (SELV) with limited power capability.[
And that was where I made my mistake. I saw that they said the 3v and 5v pins can be used as outputs...so I did. That's how I powered my GPS and RX. No problem there.
The problem was they never specified where to attach the 5v power supply when not powering it through the st-link connector.
Silly me I assumed that would be the VDD pins and that there would be regulators between there and the 5v/3.3v busses.
Um...no. Last nights studying of the schematics revealed that VDD is tied to the 3.3v buss.
For the past year I've been flying this with the 3.3v F4 chip wired to 5v. I even hooked up my multimeter and confirmed, with 5v on the VDD pins I was seeing 5v on the 3.3v pins
I'm still not sure how they expected to have external 5v applied to the board. I'm guessing either with a USB adapter or through the SWD port based on their mention of D2/D3 protecting things since those are part of the ST-Link portion of the board. I haven't bothered to look at the schematics and figure it out.
Because at this point after running a 3.3v processor at 5v for the past year (miraculously with no magic smoke!) I just can't trust it. Add in the mess with the second USB port and the lack of internal sensors...really this thing is a horrible choice for a flight controller.
The new project is dropping flyingF4 support based on what we learned last night and I supported the decision.
So the flyingF4 knuckle tau is grounded with no brain
But that doesn't mean it's dead for good. It will be back
One of the devs has offered to send me a spare sparky board so I can continue testing
It's not a 2.0 but it will still be good for testing stuff and I'll finally have a real fully supported target on my test quad
(I have the Brain on my hex but I'm not willing to test anything that isn't at least release candidate level of proven on there.)
The guy leading the new group is also convinced he can get Tau's autotune working on F1 targets...so my nighthawk 250 will also be subjected to testing
There's no plan to get nav functions working on F1 - just not realistic given the limits of the F1. But he's really convinced he can get autotune working on there and I'm looking forward to testing it and seeing if he can actually pull it off.
So this thread is ending
But a new one will be starting when I get that new Sparky board
And more details about the new project once they've made a bit more progress
