Hello,
I'm hoping to make a 5 inch quad with around 5-8 minute flight time.
My brother and I will be racing each other, but we don't need 200km/h speeds. We'll make some kinda track and have identical quads. FPV.
We won't be using go-pros. Perhaps the split cam.
For battery I'll try to find the most optimal choice between flight time and power output.
We'll have extra batteries.
I'm considering this Armattan mongoose frame because it weighs 61 grams. It's a little weaker than heavier frames, but because we're going a bit slower it may survive some crashes?
https://www.rotorvillage.ca/Mongoose-p/frame-ar-mongoose.htm
Perhaps this emax eco 2207 at 1700KV?
https://www.rotorvillage.ca/EMAX-ECO-2207-p/emx-eco-2207.htm
This motor recommends: EMAX AVAN Flow 5x4.3x3 Prop, but should I go duo-blade rather than tri-blade to reach a longer flight time?
Would I sacrifice too much maneuverability?
Going 3 Inch quad is also an option. I just feel it's kinda too small, and the 5 inch would be more fun.
Thanks for your advice in advance.
