Help! Motor stuck on full throttle
Tom26
In my e flight Night Vapor we recently had to re solder the bettery connecter to the recever but now wenever i turn it on it goes straight to full throttle and i have no control over it.
Can you take a picture of your board where you soldered fhe battery connector?? sounds like you may have attached it to the wrong place. I can compare it to my night vapor.
SSgt Duramax
Did you accidentally hit the autothrottle? I know a guy that happened to. It took him a second to figure out why his plane was going full blast and wouldn't stop.
Tom26
Heres a photo
I can't see much in that picture because it is very blurry.
Here is a picture of the bottom of my board
Neilsmit
Hi, I had the same issue. I disconnected the motor , in order to replace it. On reconnection the motor went to full throttle immediately when making battery connection. I could control the elevator and rudder from the tx, but no throttle control. After looking closely at the socket it plugs into on the board , there are three holes. Two obvious ones and a much less obvious third. After disconnecting the two pin motor supply plug and moving it to the other possible connection everything worked ok.
How about turn on radio with motor unplugged, let it settle then plug motor in? If it's a bldc motor it shouldn't run, brushed runs as soon as voltage is applied
