Motor Thrust Angle Question
teflyer
Full Circle
Are there any tips out there for how much angle you put into for the proper thrust angle or is it guess and check?
This came after looping my plane and crashing into the ground right after takeoff. I think the motor angle was pointed a little up.
pgerts
Old age member
The angle depends on the placing and lift of the wing profile.
A high wing Clark-Y profile normally needs 2-4 degrees of down thrust.
A symmetrical mid wing don't need any up or down thrust at all.
Side thrust (right angle) depends on the moment and rotating air flow caused by the propeller.
Small high rev normally need less than bigger low revving props.
Only tests will give you the correct answer - but someone will probably have done the tests if it not your own design.
