Servo tray installed here. Per Joe's suggestion, I added little strips of 1/32" plywood where the servo's will screw in for extra hold.
Control rod tubes installed here. Although they stick out different amounts on the tray end, they are both level on the back.
And here's a close up of how much room I left for the control rod tubes at the exit points. First time I've used these, so I hope this will be a good distance.
Next is the T bracket that goes along the top of the rear turtle deck.
And here are the two pieces that make up each side of the rear turtle deck.
First glue only the bottom edge of the turtle deck sides to the fuse.
Then pull out your handy spray bottle of ammonia. Works better than water - very fast acting and penetrates way better. If you don't trust me on this tip, take it from Crash Hancock - I did.
After wetting just the outside surface of the turtle deck and waiting less than a minute, it became very flexible along the grain and with a little bit of painters tape it's now becoming curved.
While the turtle deck panel dried, I moved ahead a step to put the reinforcements in where the wings mount. To make sure everything stayed in alignment, I ran the carbon fiber tube through the big hole, and a slice of bamboo skewer through the little hole at the other end. Then clamp, add a dab of glue away from all the temporary stuff, and let it dry. Then pull the clamps and alignment rods out and finish gluing on the reinforcement.
Everything lines up, and nothing extra is glued in place. Ask me how I learned to do this process in multiple steps... :black_eyed:
Adding the brace on the back of the firewall.
And attaching firewall to the fuselage. Once the firewall is in place, the little triangle reinforcements are cut to length and added.
At this point the first turtle deck side is mostly dried out and the other side is ready to be glued on at the bottom. This is probably 2 hours later - I had dinner and a family movie break between some steps here.
And finally the second turtle deck half is sprayed with ammonia - being careful not to get anything else wet - and then taped over in place. I might have been able to do both sides at the same time, but this way works well too.
Now it's time to let the ammonia dry out overnight before gluing the turtle deck in place.
