Killed it! The guns look great. I'll be coming out with a Bf-109 upgrade package soon too, so stay tuned for that!All done. Callie graphics just arrived today- I did think about not using the swastikas on the tail (and understand why folks choose not to use them) but went with the historical accuracy argument instead. I used a spare carbon fiber rod tube for the nose and tail guns.
I'm guessing at the CG on this one- using the method Jake recommended earlier, I came up with 77cm, which seems pretty far back. I always thought CG was around the front wing spar, which I'm close with using 1.5 oz in the nose and a 3000 4s battery slid a bit further forward than in my old one. We'll see how close it is on the maiden, which will hopefully happen petty soon.
Thanks, Whit. Lots of pieces to keep a person busy on this one.
Many thanks for your help again, i have downloaded the plans but i am working on something else at the moment, 58" span multi engine so was looking for a comparison. It is a bit under the radar at the moment and as far as i`m aware it will be the first r/c flier of this aircraft. It will be hand launch again but i think it may well be well over your 110 weight wise due to the nature of the full size so i`m trying to keep the weight down for any chance of success. Fuselage is built bar the skinning and i have started on the wings this evening, once i have got the wings built with motors hung on it i will start a thread and post some pictures. What is your real name, can`t keep saying thank you CrshNBrn!......Martin
Although only 58" span it is a chunk of a plane, the wing will have to be made removable to get it into my car Marcus, if it does end up flying ok i will build a 100" one with retracts and flaps.
I was not thinking of the 110 Whit, i am building something a bit different now and i will do a build thread onece i am a bit further down the line with it. Scale butnot a Warbird so no bombs etc on this one. Wings are being joined tomorrow and then i have to work out the mountings to making them removable. May post pictures and start a thread this weekend. 😜
