rcspaceflight
creator of virtual planes
Just a random thought that I got when reading a different thread. I know a lot of people talk about how one of the problems with a multirotor is that once the battery is gone, the craft just drops like a rock.
What if you used a separate battery to power a parachute that would automatically deploy with a relay that is hooked up to the main battery?
I know the system would add weight to the multirotor, but parachutes don't weigh that much, a relay doesn't weigh that much, and you only need a small battery that could power a single servo or whatever mechanism you use to eject the parachute. You could probably even add an alarm to the system to make it easier to locate the failed craft. Both would be powered from the same battery and relay.
It could be a neat, useful Flite Test episode. If I flew multirotors I would probably do it myself. Except I wouldn't have the heart to try it out... What if it fails? Remember the Flite Test episode with the parachute in a plane? That ended well....
