it would be realitivley easy to build a stand in for a quad, replicate the weight, size shape, maybe put props on it, and drop it from various heights to see how quickly we can count on the chute to deploy...
May I just point out that the airbags can deploy ontop and below the craft orientation is a none issue. And as the would be like big fat pillows they would protect and stop your rotors spinning in decent. .. but first a simple Co2 system using party balloons should serve to test the concept using a mockup deadweight
Yeah, that's what I was thinking. Just a simple mock up with free rotating props.
This is a great discussion and I want to raise a question: What would the goal of the system be? Is it to save the majority of the craft, or just a few components? Basically, would it even be worth trying to save the motors? I know the props are out, who cares about those? but aren't motors rather cheap too? Or would you want to save those?
I think the nice thing about airbags is that you can wait until the last minute to deploy them. And actually if an airbagged quad lands on someone, the airbags would still be taking the majority of the impact. It wouldn't hurt that much.
The chute would have to be deployed quickly for best effect... and chutes tend to drift with the wind. Just saying. But a 10mph impact does a lot less damage than a 30mph impact. So even just slowing the craft down would help a lot. It doesn't have to be a big chute.
I think the problem with the airbags is the complexity of them.
This kind of reminds me of the classic engineering school project of preventing an egg from breaking when dropped from the third floor. lol.
this is true, but im not sure its the end all correct answer. the mechanics required to pop the co2 would be complex, and probably require a servo, so a servo driver would be in order, IE a receiver, or a servo drive on the arduino, something similar...
then the durability of the bags is also an immediate concern.
on the other hand I do see the value in the bags. however I do think that there will be a continuous division regarding which system would be most desirable. And ultimately its going to come down to the pilot and there preferences.
absolutely a pilots preference, the system for the airbags is easier then you think, literally buy the ones they put in your steering wheel. the release would be a 2 stage system, arduino alt and speed sensor and if that fails ie dead system total failure, a mechanical proximity trigger, like curb feelers that release when there is a system failure, I/O magnetic release. so they dont go off when your just making a harder then normal landing.
for me the goal is to prevent total destruction. i fully expect a boom arm to break in the worst case, so long as 80% is safe and ok its as the swede says "landed" lol.
Just strap one of these to each boom! http://www.amazon.com/Ball-Bounce-Sport-TOYS-Teenage/dp/B00D9TDZLA/ref=pd_sim_t_5
First time chiming in on this thread...
First off, I have seen parachute deployment as an option on a number of commercial fixed-wing UAV products. I believe the idea here is to make "landings" easier for non-pilots. An autopilot needs merely to return to a fixed point at several hundred feet of altitude and deploy the parachute. So in principle, the concept is completely viable.
I can think of at least two cases where automatic parachute deployment could do more harm than good:
1. At high altitudes on windy days, parachute recovery could lead to substantial drift, possibly into an inaccessible area.
2. A parachute could make recovery from a tree much more difficult. A multi-rotor stuck in a tree could probably be brought down with some good shaking. With a parachute, it is stuck up there for good.
If you want to go the parachute route, be aware that it often takes several hundred feet for the parachute to deploy and slow descent to safe speed levels.
In terms of implementation, I would strongly suggest investigating how parachutes are deployed in the amateur rocketry community. In almost all cases, a small pyrotechnic charge is used to deploy the parachute. This method is simple, reliable, lightweight, and inexpensive.
Compressed air deployment is only used for high-altitude deployment. CO2 systems are complex, expensive, heavy, and prone to failure.
Servo-activated spring deployment systems are common in the water-rocket community. I have seen a number of designs that appear relatively simple, inexpensive, and can be constructed with common tools, but I do question the reliability of deployment.
Regardless of how the parachute is deployed, careful packing is required for successful deployment and quick inflation.
You are going to want to stop (and ideally brake) the motors before ejecting the parachute to avoid fouling.
So its not going to be planned or expected, motor breaking will be the last thing on your mind.
Is that too heavy? I may have to rethink this one then!O yea, 16 lbs of landing gear. Where do I sign up?
Thurmond
