In 1961 RC was not unknown but the commercial stuff was completely beyond the pocket of a school boy.
Like many things at the time the cheap solution was a kit that you built yourself. The kit included a circuit board and loose components that you had to solder on.
The receiver.
It had 5 transistors and needed a 3V supply.
The transmitter was even more basic and used a single 'tube'. You had to build the case yourself.
Note the huge battery compartment to house the 90V HT and the 1.5V heater batteries.
Just an On/Off switch and a single press button
Nominally 25 meg but with no crystals it was just a case of tuning the Rx to the Tx give the maximum range. The actual frequency was any bodies guess!
I built a simple all balsa glider that used a rubber driven escapement - one press left, a double press for right. It had a 3V dry cell in the nose for power and ballast.
It more or less flew but the rudder effect from the V tail was negligible so calling it radio 'controlled' was a bit of a stretch.
In those days the only thing that was guaranteed was failure, any success was pure luck!
The receiver.
