Hello all,
I began attempting my first scratch build last Thursday after my beloved Aeroscout met a tragic demise. Salvaging the Aeroscout's 2306-2250kv motor, its 25A ESC I decided to attempt using them in a Mighty Mini. I've been an inspired FliteTest fan for 10 years now and also decided to use this as an opportunity to try my first scratch build.
The build was a constant learning experience that has really gotten me excited about scratch building.
I used some foam that I found at Walmart called Foam-Cor Pro that is 5mm thick and heavy, although I didn't realize that at the start of the build... I'll have the weight ratios of the foams soon.
Despite having to cut a larger wing hole to accommodate the 5mm thick foam, the build actually went rather smoothly and I attributed most fit issues to my imprecise cutting. I didn't start getting worried until I realized that the fuselage+tail planes mated with wings seemed rather heavy. I forgot what the exact number was, but the airframe alone, with no electronics weighed in the neighborhood of 260g... not the sub 250g backyard flier I had set out to build, and not the projected 204g.
The fit issues became extra apparent when for some reason the battery hatch and cockpit formers wouldn't fit properly. I also had to modify the tail plane tabs to fit properly. I decided to ditch the cockpit/turtledeck accessories, for reasons that are beyond me. No landing gear for now. Holding on to the outlandish hope that it might still be 'floaty'.
Here we are, with my first scratch build, the Mini Sportster with 9g servos all around (what I had), a lemon RX receiver, the Aeroscouts guts, and a 1300mAh 3S that it balances out perfectly with. Weighing in at 438g grams, I question if this thing will climb or even accelerate in any direction but the ground.
Maiden flight is tomorrow morning. Palms sweaty n' all that but I'm nonetheless thoroughly excited and honored to join the scratch building community.
I look forward to hearing any thoughts, comments or advice for the future.
P.S. For my backyard flier, I'll just stick to buying a speed build kit of a mighty mini for now.
________________________________________________
Current Hangar: PZ T-28 Trojan, FT P-40, 2x FT Bloody Baron, Night Radian, FT Simple Scout, Aeroscout (†)
