starletzzang
Hello
I made my second plane, ft explorer, following the simple cub and almost completed it.
I have a few questions.
1. I moved the tail wing forward about 10cm shorter because the center of gravity did not match well. It is known as a structure that can adjust the center of gravity by moving the tail wing. Did others do the same?
2. The center of gravity is not right, so I have only 3S 1100mah (weight: 120g) battery, so I added lead (weight: 5g x 10e) to match the basic 3S 2200mah weight. Wouldn't that be a problem for the flight?
A typical 2200mah weighs about 170g.
3. The total weight including the battery is about 950g.
The ft explorer page in the flitetest shop says the weight is 2.25LBS (1020g), is my weight correct?
How do other people get the weight of the aircraft fuselage?
4. Motor used a2212 1000kv, propeller used 8x4.5 Slow flyer. It weighs 950g, is it good performance?
Thank you, I have a lot of questions, thank you
Have a nice day
Have a nice day
