JasonK
Participation Award Recipient
I checked my CG setup with the cgCalc
https://www.ecalc.ch/cgcalc.php?dee...75;0;0;0;0;2.5;0;0;0;.75;5.25;0;0;0;14;25;10;
photo shows were I had my CG (approx at the holes) and the lines are were the cgCalc says were my CG should be (way farther back) I tried test tosses without the battery which puts the CG between the indicated locations and were I have it and it glided great. The cgCalc also has my stability higher then that of a trainer, so If I am understanding this correctly, I have way more tail then needed (does that sound correct?).
At this point to get my CG between the 2 recommended marks from cgCalc, I would need to mount my battery behind the CG (or at least overlapping it).
