As soon as the props start spinning the baro graph starts to move down quite a lot. You can see the screenshots.
This is with the foam.
I tried adding electrip tape on the sides to isolate it even further, but it was about the same.
Needless to mention altitude hold doesn't work at all. I'm trying it in angle mode as primary with mag and baro as seconday all at once.
It behaves about the same as just in angle mode.
What else I could try to make this baro work?
