RichardEllis
Hello everyone, I have been doing a little research on the web and on here but still can't find a straight answer. I am building a quadcopter and I think I have bought too low of C rating batteries for the setup. Everything was purchased together from hobbyking and will have no previous use (batteries are new). Here is everything I plan on putting in the setup:
-Two Turnigy 2200mah 3s 20C batteries
-Four DT750 motors, draw max 18amps each with 11" props. (I will actually be running the 8X4.5 SF props)
-Four Turnigy ESC's each rated at 25amp
So if I am correct, 4 DT750's together will pull a max of 72amps (4X18amp) full throttle. The battery is 2200mah with 20C means (2200mah X 20C = 44amps). Can I run 2 2200mah in parallel to give me the same voltage of 11.1v I need but increasing the amp capacity to 88amps be efficient and safe???
***please be nice, I am still a noob to this hobby, yes I did search already***
