Hi! I'm planning on building my first RC airplane, which means essentially buying a lot of different Equipment like servos motors etc. I saw a video by Joyplanes where he built a plane with a 1.3 meter Wing and 0.9 meter fuselage. My point is that the plane was big. For the plane he recommended a 1000KV motor that weights 33g. Then i looked at another video and saw about the exact same plane but smaller size, 1 meter Wing and 0.7 meter fuselage. The plane was a bit smaller than the previous but very similar. In that plane he recommended a 33g motor with 2200 KV. Now, to the question. Can the 1000 KV motor be used on the smaller plane? It was able to lift the bigger plane so the smaller one should be no problem right? Or is the extra KV that the other motor had necessary for the smaller plane to fly? To sum it up I'm wondering what the extra 1200KV the smaller plane had does? Is it simple just because it will make the plane go faster or is that extra KV crucial for the smaller plane?
