Help! Need help with CG of a scratch-built canard
Dereeki
I had some extra foamboard laying around, plus some electronics from a FT millenium flerken that I had crashed awhile ago, so I decided to try my hand at designing and building a plane out of these parts. I ended up with a canard design that used 3 servos for all the control surfaces (one for each aileron and one for the full flying canards up front) I am not quite done with the build, as I need to cut out and glue on a vertical stabilizer, and a prop guard on the bottom. I am aiming to us a 1300 mAh 3s battery to power this plane, and as this is the first plane I have designed myself, I have no idea how to calculate the center of gravity. Is there an equation or website I could use for this? or just trial and error?
Mr NCT
VP of SPAM Killing Striving for Mediocrity
View attachment 245291 View attachment 245292
Here's an easy calculator that I used for a LongEZ. Get out your tape or ruler and enter the numbers.
Mr NCT
That's the furthest forward point on the canard. Not sure how this will translate for a full flying canard but should get you close.
Shurik-1960
You forgot to glue 2 keels on the sides of the fuselage and your duck will fly steadily. I take a piece of plasticine (by weight of the battery) and attach it with 2 rubber bands to the fuselage of the model. Throwing in the planning, I find the perfect place for the battery and CG.
