I would double check the control surface throws using the gauge in the kit. I was using too much throw and the plane was all over the place. After cutting back the throws it is well behaved.Hey everyone. I’m in the transition between quads and fixed wing. I’ve been watching all the FT videos and all those planes look so much more stable then mine. I just recently built a FT Tutor. Any tips for a newbie would be greatly appreciated.
+1 on getting the CG and throws right, both are critically....Any tips for a newbie would be greatly appreciated.
Solid.CG is critical. If you're measuring CG with your fingers, stop doing that and build a simple CG machine, make marks on your wing and measure properly.
That and building square are probably the most important. I've built the Simple Cub from the speed build kit and scratch built the Tiny Trainer and the Mini Sportster. I haven't flown the Mini Sportster, yet, but I know I built the tail section crooked and will probably just re-build the whole plane. I'll try it the way it is but don't have a whole lot of faith in it.
I'm not crazy about the wing design of these FT planes, so I went with a KFm-3 wing on the Tiny Trainer and like it a lot more than the FT design. Bonus: it's WAY easier to build.
Edit: one more thing, EXPO! If you haven't already, add 30% expo to rudder, elevator and ailerons. Also, I'd recommend setting up dual rates if you can. Very small and light stick inputs. It's amazing how much reaction you get with very little input.
Thats a good idea. I’ll check that.I would double check the control surface throws using the gauge in the kit. I was using too much throw and the plane was all over the place. After cutting back the throws it is well behaved.
coffee...
word.Here was my journey until I actually had a real "flight" that lasted longer than 30 sec. And these are in the order I built and flew them : FT Alpha x2 (not a beginner plane LOL), FT Sparrow x2(another bad beginner choice), FT MM Corsair, FT MM Mustang (some success with this, but too small and too fast for a beginner), FT-22 and Mini FT-22, FT Tiny Trainer x2 (limited success, this plane does not like wind,) and then I built the FT Racer and it was a game changer. That plane is still one of my most favorite, hands down. Very easy flier, and allows you to build skills that you need to be able to fly smaller planes. IMO a larger plane like this would be a consideration because you have a little bit more time to react to the plane and It is much easier to see and keep track of your orientation in the sky. I built 3 of these plane and they all flew fantastic, I still have one in my hangar and when it gets to a point of no repair I will build another one if for no other reason because it just looks coolSo I guess what I am saying is that bigger planes are easier to fly , not just my opinion but something I have heard repeatedly. Best of luck in whatever you decide on, you'll get it. Build,fly,crash,repeat , words to live by in this hobby
Still waiting on plans for the CG machine
What you gain in speed build and performance, you lose in stability. The majority of FT wing designs incorporate some amount of undercamber at the tips, this inherently reduces tip stall, very helpful for those new to the hobby. Even with some undercamber, my FT simple cub was a pig at slow speed and loved to drop a wing.CG is critical. If you're measuring CG with your fingers, stop doing that and build a simple CG machine, make marks on your wing and measure properly.
By CG machine I presume you mean the COFFEE GRINDER.Still waiting on plans for the CG machine![]()
What size Lipo does it take?My CG machine, adjustable width.
