ElevenQuad Onix 110 Frame (micro swift, top mount bat, pythagorean and more)
Hi All,
After seeing FliteTest videos about Gremlins I have been inspired and pull the trigger to design my first micro quad
This is a 110 class frame designed for 2.3" - 2.5" props. In addition to standard 1104-1106 motors, it is compatible with Emax BabyHawk/FT Gremlin and Blade Torrent 110 components.
Features :
Current version : 1.0
Next steps :
Waiting validation from Armattan
Design a new frame based on this one but much lighter (2mm bottom plate)
Hi All,
Features :
- 111 mm motor to motor, 3 mm bottom plate
- 2.3" or 2.5" props
- 1104 to 1106 motors
- Compatible with Emax RS1104 motors and all others Emax BabyHawk components
- Compatible with Blade Torrent 110 components
- Same geometry than ImpulseRC Alien frame (pythagorean 3:4:5)
- Runcam Micro Swift
- Top mount battery !!!
- Cam angle from 0 to 90 °
- Estimated at 15.6g of carbon (without optional back plate)
- Optional 0.5g back plate to make the frame stronger
- 3 very light M3 standoffs thanks to outer diameter of 4mm
- 22mm long standoffs, enough to mount 3 stack plates inside (fc, esc, vtx, rx, osd...)
- Plenty of spaces on arms to mount individual ESC such as EMAX 6A/12A Bullet
- Support 20x20mm mounting holes flight controller (soon: 3D printed adapters for other formats)
- Flight controller position can be adjusted back and forth to improve gyro position
- Top plate is big enough to support 61mm long battery
- ATX03 or VTX03 mounted inside with display visible on top
- Compatible with FrSky XM/XM+ receivers
- Easy access to VTX channel button and RX bind button
- VTX and RX can be secured with zip ties
Next steps :
