RCdiy
RCdiy
https://www.youtube.com/watch?v=eCgTx82aoGI&feature=em-upload_owner
OpenTX 2.2.0 RC12 (N364)
http://www.open-tx.org/2017/03/13/opentx-2.2.0RC12
OpenTX 2.2 Sound Packs
Official sound packs are obtained from Companion > File > Download
There is now a version file that is checked to help determine that the firmware and sound pack match. No more wrong units due to mismatched firmware and sound files. Checks for the existence and content of opentx.sdcard.version in the root os the SD Card. You can still use your own files but make sure you have this file.
Additional sound packs posted.
https://github.com/RCdiy/OpenTxSounds/tree/master/2.2 Sound Packs
Generated using Mac voices.
OpenTX 2.2 will be out soon.
Check out this blog post and video to find out what has changed and what has been added.
http://rcdiy.ca/opentx-2-2-whats-new/
New
Changes
Companion
Companion Simulator
Horus
There are many new additions. Here are a few.
New
- Support for the FrSky Taranis X7 and Horus
- Support for FrSky S6R receiver (configuration wizard on SD Card download)
- Support for Team Black Sheep Crossfire telemetry and updated protocols
- Support for the external DIY Multiprotocol Module
- Sound pack incorrect version warning. No more incorrect sounds when our sound packs are used. Checks for the existence and content of opentx.sdcard.version in the root os the SD Card. You can still use your own files but make sure you have this file.
- New DISPLAY screen to configure LCD display options
- Reset Flight now also triggers all the same warnings (if any) as when radio is turned on
- Added the option to use a system bye.wav to play on shutdown
Changes
- BMP folder renamed to IMAGES
- Curve names shortened to 3 characters (was 6)
- GVAR names shortened to 3 characters (was 6)
- 64 Logical Switches (was 32)
- Lua file names shortened to 6 character + .lua (was 8 + .lua)
- tada.wave has been renamed to hello.wav
Companion
- New .otx file format
- Radio Types for FrSky Taranis and Taranis Plus renamed to Taranis X9D and Taranis X9D+
- General Settings replaced with a Radio settings button on the model browser window
- MAC dfu-util is now part of the Companion install
- Firmware build options “no timer 3” removed, timer 3 always included
- KML export for Google Earth now always uses meters for the altitude
- Chinese language support (Companion only)
Companion Simulator
- Redesigned windows
- Reload Radio: Same as turning the radio off and then on
- New option to keep momentary switch SH in the active position
- Switch/know/slider positions are now saved per radio profile, and sticks are properly set up for the corresponding mode
- configured in the radio general settings.
- Improved support for smaller laptop screens
- Switch/know/slider positions are now saved per radio profile, and sticks are properly set up for the corresponding mode configured in the radio general settings.
Horus
- Support for PNG and JPG image files, 192 x 114 pixels
- Emergency shutdown by holding the power button for 10 seconds
