soundnfury
For several years I've had a goal of building an RC plane out of paper and Scotch tape, making use of rolled paper tubes for main structural elements. This goal got a lot closer on July 20th with the first test flights of the M8 Condor. This is a high-wing monoplane with straight wing and conventional tail (leading-edge sweepback ~30° on fin) and an open-work triangular fuselage. In a departure from 'paper purism', the mainwheels and tailskid are made of foam. The wing has two spars, one at the leading edge and one at about ⅔ chord.
Flying controls consist of a single central elevator (with inset-hinge balance) and ailerons at the wing-tips with horn balances. (No rudder.) All are actuated by opposed pairs of darning thread in tension.
Main dimensions (approximate): length 3ft, span 4½ft, chord 6”. All-up weight is about 315g (just over 11oz).
First up were some taxiing tests. These are the only bit I have a photographic record of.
Photos of preparing for taxi test: #1 #2.
Video of taxi test.
Apart from some trouble with torque reaction (and concern about the low ground clearance of the aileron control posts), this all looked good enough, so we then took the 'plane to a nearby park to attempt to fly it.
First up was a chuck glide test. It was immediately clear that the aircraft was tail-heavy as it rapidly stalled, so we added about 25g (1oz) of ballast to the nose. On the second try it made a fairly controllable glide and landed fairly smoothly, so we then went ahead with a powered test.
Launching at about 50% throttle, the 'plane started losing height straight after the throw; lacking experience I pulled the stick back and stalled it. Trying again with full throttle, the 'plane seemed to fly (just about) but started pitching up too much (there isn't much elevator authority). Stupidly I reduced throttle, and it stalled again, having spent only a few seconds in the air. The repeated crashes were taking their toll and on the next launch it turned out the main spar had cracked at the left-hand fuselage joint, causing the 'plane to roll violently to the left despite full opposed aileron. So that was the end of "flying" for the day, and the wing is currently sitting in my room waiting for repair. I also plan to increase the elevator chord and possibly aileron throw, as well as lengthening the motor mount to bring the CG forward a bit.
Video of taxi test.
