Plane powered by a pc fan
Non Action Man
Nose Landing Specialist
How about a challenge to build a plane that uses a pc fan? I have seen one, but it was modified by using the blades with a higher speed BL motor.
FT, can you make and fly a plane solely powered by an unmodified pc fan? You can use any off the shelf pc fan, with original fan motor. Any size from 240mm down. Voltage is up to you though- make that sucker burn!
Obviously it's going to be hand launched, but can it be done?
NAM
ananas1301
Crazy flyer/crasher :D
#3
Yeah it would but only if you really don´t modify the fans
they should stay original, whichever ones you take! Would make it more of a challenge :)
SunShine
not crazy, just stupid
#4
we should specify witch fan to use, there are a lot of fans out there with insane performance. it would not be a challenge to make an akasa viper fly..
However im a fan ( ;) ) of the idea
bicyclemonkey
Flying Derp
I connected a PC fan to a 12v battery years ago and it moved enough air to lift itself. Who knows how long the little motor inside a PC fan will last if supplied with enough voltage to move a plane. This would be very cool to see!
colorex
Rotor Riot!
All the PC fans I have seen are designed to go slow and quiet... But I have never seen a high-performance fan.
@Sunshine: Excellent pun!
