Hi,
I am new to any RC builds. I thought of building a quad rotor. Below is the list of things I bought for my build.
- HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=19534
- Hobbyking SS Series 8-10A ESC
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6455
- Turnigy 1300mAh 2S 20C Lipo Pack
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9165
- Hobbyking Super Mini Quadcopter Frame with Motors (445mm)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20946
- HobbyKing HK6DF 2.4Ghz FHSS 6Ch Tx & Rx (Mode 1)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16238
- Male XT60 connectors (5pcs/bag) GENUINE
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10414
- Spare Rubber Ring for Prop Saver (10pcs)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8234
- 5x3 Propellers (Standard and Counter Rotating) (6pc)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11328
- 5.6mm x 36mm M3 Nylon Threaded Spacer (10pc) (Not received yet)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=22735
- HobbyKing ECO6 50W 5A Balancer/Charger w/ accessories (Not received yet)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11060
- Ace Bullet Male Disconnect & Female Disconnect
http://www.amazon.com/Pk-50-Bullet-...ref=sr_1_5?s=hi&ie=UTF8&qid=1334415520&sr=1-5
http://www.amazon.com/Pk-100-Bullet...ref=sr_1_6?s=hi&ie=UTF8&qid=1334415520&sr=1-6
- Twisted Servo Extension Cable 12" Female - Female
http://www.pololu.com/catalog/product/2166
I did all the connections. Am I correct in assuming that it is a pre-programmed controller and all I have to do is plug and play. I connected all the wires to the control board. When I connect the battery after all the connections, I see a solid red LED light on the control board, solid green on the receiver and solid green on the transmitter. When I tried moving the sticks on the transmitter nothing happens.
I tried keeping the throttle in the low position, all trims in the middle before connecting the battery. After connecting the battery I moved throttle to left and right.
To check ESC and motor 1 (2, 3, 4), I connected ESC to receiver throttle (3rd position). Turned on the transmitter with throttle high position. Connected the battery, heard a musical tone, when I move the throttle the motor responds.
I attached few images below.
Thanks in advance.
Thanks in advance.
