Power Pack C BEC on a twin motor set-up
chris398mx
Can the BEC wires from both speed controls from Flite Test radial powerpack C be left plugged in when connecting to the receiver? If so, does this double the available amps for the servos to draw from? They are 35 amp with 3A 5V BEC's. @Wildthing @SquirrelTail @The Hangar @rockyboy @sundown57 @Joker 53150 @Grifflyer . do any of you know the answer? Thanks for any feedback.
I'm Not named above, but I think you need to modify one of the ESCs by removing the red wire from only one ESC so the one BEC portion doesnt fight the other. If you are using a "Y" adapter do it there. Just pull the pin out of the connector, then tape it, that's easiest. The motor wires can be left attached forever or until the first really good plane destroying crash which should unplug them for you.
