bprodgers21
Just curious if anyone here has had success using the PPM out from the Orange OpenLRS Rx. I've tried it with both a Naze32 and a KK2.1 board (not at the same time ), but neither recognizes the PPM signals from the Rx. Here's how I had it set it up:
Rx: Running latest version of OpenLRSng, jumper on signal pins of channels 7 and 8 per manual, using PPM out from channel 5/port 6. Limited PPM out to 8 channels in the Chrome configurator.
Naze32: Plugged into the three leftmost pins on the top row of the inputs per manual. Enabled PPM feature in CLI under Baseflight configurator.
KK2.1: Running Steveis 1.12? (don't remember exactly) beginner firmware. Enabled PPM in menu and configured channels to the order that my Rx is set up for (TAER, aka JR/Spektrum). Plugged the PPM cable into the aileron input pins.
Neither board is recognizing the PPM stream from the Rx. I've read things about sync time and pulse widths, but I haven't messed with these things yet. Anybody have some experience here that can offer suggestions? Thanks in advance.
