I'm building this little fattie profile. I want to mount an 1806 (type A) motor to the front, which (as you can see) is in a cross pattern of DTFB.
I made a printable prototype (shown here in black PLA), but I'm not happy with it, because the firewall doesn't hold firmly to the part that's supposed to hot-glue to the foam board.
I'm proud that the plastic part is only 4 grams, but I'd be willing to add weight to insure that the two parts hold securely together. Why two parts? Because the last mount I made for such a plane worked, but trapped the motor mount screws between the firewall and the DTFB, and now that they're all unscrewing themselves, I have to tear apart the glued nose to fix it. I'd rather engineer a mount that lets the nose of the plane survive when I have to remove and replace the firewall.
Have you seen a better way to make this motor mount? Any helpful ideas? Thank you!
