Pieliker96
I figured that trying to troubleshoot my old Printrbot simple was too much of a hassle, so I'm starting new, and repurposing it. I'll be reusing the bearings, steppers, endstop switches, and controller board, and building an entirely new frame.
I've got all of the parts I need either at my house or on the way, and they should all get here within the next month.
I would use lead screws, but the carriage and gantry will be light enough for belts, especially with 2 motors on the x axis. The bearings will be attached with a little indentation into the MDF and some zip ties (Sounds sketchy but works great with low loading)
All rods are 8mm diameter. The X axis runs on 1000mm rods, the y-axis on 600mm. I doubled up the X-axis rods to reduce sagging at long lengths, and this was cheaper than buying new bearings and a thicker rod.
The Laser I am using is this. It should have more than enough power to get through the paper layer, although I am not sure about cutting through foam. Either way, It's still better than tracing everything out myself! It will be plugged into the fan port on my controller, which provides the required 12v.
The base and all of the rest of the machine is cut from a sheet of 2'x4' 1/2" MDF.
The cutting area is exactly one sheet of DTFB (20"x30")
Total cost was just shy of $150, including shipping and stuff like eye protection
That's all for this post, feel free to critique my design, as I haven't designed a CNC machine before. I think this should work fine, but let me know if there are any obvious flaws.
