My problem with all this, and why I asked the initial question, is finding a real pusher prop.
When used with my prop-saver, all the props I’ve found only sit securely on the shaft (and up against the prop saver) with their reducer/adapter-side towards the motor. Mounted like this, to work as a pusher means that the designed following-edge becomes its leading-edge. So, the motor spins one way and the prop is an inefficient pusher. Reverse the motor and the prop efficiently makes the plane go backwards.
Where can I find a prop that will work with my motor? Or make all the other ones function properly?
