PWM RX INPUT IS DISABLED IN INAV 2.3.0 (I am using spracing F3)
how to enable pwm rx input for spracing F3 IN INAV 2.3.0 it is not enabling ,
need help .
#2
If you are in cleanflight or betaflight it should be under the configuration tab. There should be a dropdown menu. Also make sure your TX reciever is not set for PPM mode but is instead turned off. And lastly, make sure that you have turned your esc/motor protocol to pwm mode as well. If there is a chance since you are a starter, use PPM it makes things so much easier.
