Queston with P-effect
quackeroats64
If I built a twin motor plane, and both props were rotating counter-clockwise then the plane would yaw to one side. Would moving the engines closer or further from the fuselage minimize the effect/yawing (would moving the engines away from the fuselage make the yawing worse or better?)
L Edge
Get a set of props so you have a CW/CCW with the motors. If you sync them, no problem. If you set up with differential thrust, you have your yaw to turn.
