Help! boomin flerken prop direction?
Greg987654
On The boomin Flerken with twin props, the Left motor should rotate clock-wise. What orientation does this mean? Does the "left" motor mean the port side, ie. to left when viewing the plane from the rear? And does that motor rotate clockwise when viewed from the same direction, ie from the rear of the plane? This is how most full size planes with wing mounted twin props with counter rotation are arranged but it is not clear from the Flite Test build video with Josh. Thanks for any input!
On full size planes, the props rotate downwards. That is as the prop tip is nearing the fuse it is going down & the tip away from the fuse is going up.
