Well, I *was* going to work on a P-47 now, but a small series of events has changed my plans. A few weeks ago I ran across a guy who was selling a couple Zenoah gas engines, a 20cc with electronic ignition and a 38cc with a magneto ignition, both of which are now mine (I can't pass up a great deal). Then yesterday I ran across an RC Guys Cessna 188 "AGwagon" (agricultural wagon, AKA: cropduster) on FaceBook Marketplace, which is designed for up to a 40cc gasser. It was meant to be!
The seller wanted less than half the price of the new ARF, and it came with most servos and a smoke system. No engine, a little hangar rash, needing some electronics. The plane is actually still available new, although in this case I don't really need any parts from them. If I like the plane after it's done and flying I may go ahead and re-cover the wings as they're a little rough.
These first pics are of a finished 188 I found online, not my plane.
Here's mine, shortly after getting it home and putting it up on the stand for inspection. Both wings have their servos, there is a servo for each elevator installed at the rear, and there is a servo in the nose, possibly for the throttle. It's missing the rudder servo for the pull-pull rigging. The smoke system is controlled by the receiver and programming, no servo needed. The original ARF included plastic covering for the control surfaces which mimicked the corrugated material the original used. It appears this plane originally had that installed as all control surfaces show signs of re-covering and repair. Wings are both solid and I didn't find any broken balsa there or in the fuselage (yet), kind of a first for my projects!
Here's the Zenoah G-38 I picked up. It's been fighting my attempt at getting it running, but I think I'll win. A previous owner did a lot of "creative" work on it that I'm attempting to un-do. First, a home-made carb mounting block was made for it to turn the carb and make hooking up the throttle pushrod easier. If you saw my build thread for the big blue "Nothin' Extra" you may remember the bellcrank and linkage needed to make the throttle work. The carb mounting block this engine had does away with that and gives you a straight shot from the servo to the carb. The downside? In this case it also required another fuel line to get the "pulse" from the engine to the carb to pump fuel. A semi-flexible fuel line isn't going to give me a good solid and reliable pulse like the original setup, so I'm getting rid of the home-made stuff and going with a stock-type setup. Actually, I also ordered another carb block that may work better than stock, I'll compare the two and go with the better option.
The carb has been disassembled, and again I'm un-doing previous alterations. First, I had to remove an elbow mounted into the back plate of the carb. This is where the pulse line from the mounting block attached. When the parts are cleaned I'll plug the hole as it won't be needed. I also removed some type of Bondo-ish material used to block the pulse inlet port on the carb, as I want to use the port again. The pieces are all disassembled and ready for a soak in Denatured Alcohol for a few days. Before this pic was taken I spent some time cleaning the major dust & dirt off the carb so I could more easily disassemble it.
The stock muffler in the bottom right of the pic is being replaced by a B&B smoke muffler designed for the G-38. I've never had a smoke system, and this one has a Sullivan Sky Writer pump installed.
As with my other G-38 engine, I'm replacing some pieces that are probably still OK with new ones, especially if the new parts are cheap! The plug wire and plug cap are about $3 for the set, and since the pieces that came with the engine were getting crusty it was an easy decision to swap 'em out. Until I tried removing the old parts...
Somebody put some epoxy or other fairly aggressive adhesive in the coil to hold the plug wire, and it was a beast to remove. It took about 20 minutes of picking at it with the Harbor Freight picks shown below, but I finally got the old stuff out and reinstalled the mag back on the engine.
A new plug will go along with the new plug wire and cap, a new exhaust gasket goes with the new muffler, new carb mounting gaskets with the new carb mounting block, the carb is getting a full re-build, a 3-1/2" spinner, and maybe a few other tweaks, and it should then be ready to mount in the plane. Hopefully the engine mount that's shown doesn't require any work to get proper prop/spinner placement at the cowl, I haven't checked that yet.....
