Hai-Lee
Old and Bold RC PILOT
I am currently a very busy lad, being a trainer and support volunteer at my local club as well as being a constructor for a local retail outlet. Part of my duties as a volunteer to is assist other club members in getting their new purchases or creations into the air.
Well I do not currently use Spektrum radios and of course their are a number of Spektrum radios being purchased and a lot of what I call entry level junk, (including a lot of vendor specific radio systems). In addition I fly mode 1, (I started in RC when 27MHz was the band of choice).
Well some radios I can buddy box to but I do not have control of when the control is handed over and so in some/many cases by the time the control is handed over the bird is doomed. The one problem I have is that often even when the control is handed over with sufficient time ot normally effect a save the radio system often has or is in a LOS condition where my control inputs are not received by the doomed plane.
In my various meanderings around the internet I actually found a device that actually allows me to connect my own receiver into the Plane whilst not upsetting the original radio control system. With the device I can switch between receivers at will and so in the case of a LOS or other control issue I can assume control to save the plane from crashing.
It also allows the original radio system and installation to be compared directly with the radio system and antenna setups I recommend and use religiously.
Whilst I have found 2 such devices so far this one is the cheapest and simplest to use version I have yet found and so I am awaiting its arrival.
https://www.banggood.com/RC-Model-T...ane-p-1616037.html?rmmds=buy&cur_warehouse=CN
I can even setup the bird to switch to the second receiver in the event of a LOS event, using failsafe. Now I can plug my Rx into those doubtful quality retail offerings and give some amount of protection from crashing for almost any radio related reason. All that is needed is for the original receiver have standard servo PWM outputs and I can plug on in.
No more need for dodgy buddy box cables or even vendor specific equipment!
More on its performance when it is finally air tested.
Just a heads up on what is out their for us to use.
Have fun!
Have fun!
