rpm drop
theo44
Can someone tell me the rpm drop of a 1806 2280kv with a 3s battery once a prop is installed say a 6-3?
thanks
quorneng
theo44
Technically a brushless motor is a constant speed device. The maximum rpm it will run at depends of the voltage applied to the ESC. The motor will try to achieve the kV times battery volts (2280x12=27,000 rpm in your case). What is important is the specified max amps for the motor. This normally results in about a 15% drop from the "calculated" max rpm to about 23,000 rpm in your case.
Exceed the max amp figure by fitting a too big a prop the motor will still try to achieve the same calculated rpm so will draw still more amps and burn out sooner or later. :(
It is the amps (which can be measured) that the motor draws to drive prop at full power that is the limiting factor not the achieved motor rpm.
theo44
I agree, But that motor is not turning, i don't think turning 27000 with the prop on. I thought some one might of put a tac on a proped motor to see the rpm's.
